Aleph 30 diy - total beginner
Assuming you've checked and verified the bias current, you should also
measure the DC offset (between +/- output terminals). You want it to
be low, say less than 50mV.
If DC offset is fine, then you can try hooking up some test speakers.
Dennis
Thank you. I measure it this evening. Which courrent value may I see?
What resistance value did you use for the source resistors? The Aleph 30 calls for 0.47R and the manual says each resistor should have 0.25V across it, as Dennis pointed out. This translates into about 0.5A through each vertical pair of MOSFETs, or 1.5A total bias per channel.
Of course, if you used a different value for the source resistors, then you will see different numbers.
