Aleph 30 diy - total beginner
Yes. I-Fet is an electrical way of saying current in amps per fet. PWR is expressed as usual in Watts.. which equals the resulting Pd (power dissipation) in watts. Generally speaking, large signal fets such as the sort in question are capable of dissipating a certain number of watts, which in turn is dependent on your ability to cool them. ie, how much heatsinking are you using? If that answer is "i have adequate heatsinking" capable of say.. 120 watts at a 25deg C rise. Then you are capable of running those Fets at 30 watts a piece, and whatever current (I) that is proportional to that Pd, at a given voltage of the power supply you are using.
I bought a toroidal transformer (600VA 20-0-20 V) and now I'm doing the part list to order on digikey.
Now, I'have a question about the resistors on the Power supply board.
I use the BrianGT boards. For the Power Supply, BrianGT give the part list and, for the resistors, at the position R3-R12 there is a description that says to use a short circuit jumper and a note says "for the standard CRC configuration, no R is needed".
Shall I let the position R3-R12 empty? Or must I use a piece of conductor to do a short circuit?
Thank you
Thank you
I used the same board and used the jumper wires without a problem. I would build as suggested for starters.
I find that note in the BrianGT BOM confusing. Aren't those resistors the "R"
in the CRC configuration? With jumpers you get a straight capacitor supply
(not that there's anything wrong with it.)
Dennis
I actually replaced all my jumpers with .47 resistors at a later date. I did not notice any difference actually. I am like you and did not like the board or the fast diodes. I removed the capacitors at a later time and just wired my PS point to point using bridge rectifiers. There is not much to wiring a PS PP and I see no need for a board. I just thought to keep it simple for a first time builder and just said to build as described. It does work.
