Hi.
I want to build Aleph 3 ,so I need some web sait where everything is explained in detail how to build Aleph 3.
This could be the site your looking for. But, the nature of this site is DIY. No one is going to hold your hand and explain everything. You will be expected to search and make some effort on your own. I'ts also good to engage in discussions when you get stuck with particular problems. There is an unbeleivable amount of info on this site but reading is necessary.
Try the search tab up there on the right 😀
As you are from Croatia as I, try read this :
Aleph 5 - kako napraviti_od A do ?
Also you can contact Kristijan Ključarić for the parts and help
http://www.kk-pcb.com/index.html
