Aleph 3
Hello to all,
I have finished the assembly of an Alehp 3 taking advantage of some heat sink that taenia.
Which the maximum temperature that can reach the heat sink for this assembly is?
A greeting to all.
Angel Puerto.
NOTE: Excuse for my English so bad.
I'm not shure if this info is what you are looking for but the rule of thumb for heatsink temperature is not to exceed 50'C. -> You should be able to touch the heatsinks without hurting your hands. The aleph 3 puts out some 200W of heat. This meas your heatsinks should have a total rating of about 0,125 'C/W. Hope this helps.🙂
The problem with heatsink : I'm used to see a lot of heatsink without there value of C/W.
I dont' care with the fact I take the biggest heatsink as possible.
But can we determin the dissipation power by the weight of an heatsink ( and of all others part of metal)?
Hello to all,
Here the pictures of the prototype are, they lack to add 2 condensers of
150.000 uf.
A thing that was me very well was to put 9 condensers of
2.200 uF Nichicon URZA in parallel with 150.000, in high and sharp means, transparency. Not small condensers of 0,1uF...
Greetings.
Angel.
NOTE: Lament my not well English one.
I think that this time I have made it well.
Greetings.
Angel :scratch:
The condensers are of 150.000uF 40V FELSIC it marks, but those of others
you mark they have similar dimensions, AEROVOX, etc...
Thank you Josep recommends you the detail of the condensers of 2.2000 uF it was
very good their result, guaranteed.
Thank you.
Angel. 😎
