Hi All,
Just a few more quick questions before I make this PCB (layout attached).
Do the input fets require heat sinking or at least a fair bit of clearance around them?
How much clearance should I leave around the 5W 0.47 ohm power resistors?
I have come up with a fairly compact PCB design (below) and am wondering if I have left enough space around everything.
Your advice is appreciated,
Greg.
Greg.
There is enough dissipation margin in the parts
that it's not critical.
Your layout looks fine.
