PCB for Aleph 3/30
Hello everybody !!!
Can anybody send me a project of PCB board for
Aleph 3 or 30.
e-mail: tomasz.rodak@energo-inwest.com.pl
Thanks in advance !
Hello everybody !!!
Aleph 3 or 30.
Thanks in advance !
Tomasz,
The hexfets need matching, see the passdiy.com site (A75 article), its atcually quite easy and the fun part of the project.
Your transformer should be fine for a stereo pair.
For the heatsink aim for heatsinks with 0.33 degrees C per watt or lower for a 30 degree C rise above ambient (assuming 100 watts disipation per channel). ie 1 per channel
If you can't get this low try for (2) 0.6 degrees C per channel.
Look luck with your project, the results are very worth while!
regards
macka
regards
macka
Tomasz,
Good luck with your project, the results are very worth while!
regards
macka
regards
macka
I finished the A3O ( Volksamp modification). It sounds terribly.So I changed the values to A3. It is somenthing different, much, much better. Doing experiments I removed couplig capacitor ( to current source), turning this amp to SE. I think it is the best I have heared form this amp. Except bass tones. Hi.
- Aleph 3/30
