Aleph 2 with 60V rails.
it would work. if the signal transistors can take the voltage. another thing is. do you need that voltage? it's just a waist without bias that is equal high
(if it's not a very high impedance). and then you need more outputs. in other words. you got a aleph1.2🙂
ZM. yes, if bias is not raised🙂 wich is useless not to do IF driving a 8ohm load🙂
with bias at let say 4.2A, he may want some more outputs🙂 thats 0.7A pr fet with 6 outputs. 70V*0.7A=49W dissipation pr fet. thats a little over my comfort zone for the fets🙂
