aleph 2 problem
i finished my aleph 2 cnstruction and i tested forgeting to connect the led diode. almost emediately the mains fuse was melted. i checked the circuit and after connecting the led i changed all irfp 240 of the constand current side.i found at least 2 short circuited and 2 power resistors(1om)destroyd.
i turned then the amp on and as a result after 30 sec of normal operation (dc ofset 40mvolt)the220 om resistors next to the irfps started burnig and i stop any eford in doing anything else.
question:all theese happened because i didnt connect the led ?what do i do now?
The LED should not have had anything to do with it.
Most of the time this happens there is a wiring or component
value error. Time to start looking for it, and also think about
how you can limit the supply power for next time you fire
it up.
You have almost 20% higher dissipation than stock that you need to cope with (you could reduce bias a bit) otherwise not a big topic.
Or you could burn 1 or 2 V's by building a CRC supply.
Have fun, Hannes
