This Akabak script simulates a tall BR with a RCF L18P400 at the bottom of the box and ports above. The hight of the box is just enough to stack the 18", a 10" midrange and a horn on top. I wanted to simulate a good port placement.
I started off by doing a WinISD simulation, a -3 dB bass shelf, giving about 280 liter volume.
Taking all the parameters to Hornresp, I could almost simulate the box using a stub. Anyway, exporting to akabak gave me a quick start into akabak.
I made a few mistakes. Shorting a vent to 0 is the trick for ending a section.
Hopefully this code can be reused
Code:
|COMMENT: RCF L18P400 akabak
|REQUIRED AKABAK SETTINGS:
|File > Preferences > Physical system constants:
|Sound velocity c = 344m/s
|Medium density rho = 1.205kg/m3
|Sum > Acoustic power:
|Frequency range = 10Hz to 20kHz
|Points = 533
|Input voltage = 40.00V rms
|Integration = 2Pi-sr
|Integration steps = 1 degree ... 1 degree
|Integration method = Cross
Def_Const |Hornresp Input Parameter Values
|Length, area and volume values converted to metres, square metres and cubic metres:
S1 = 3060.00e-4; |Horn segment 1 throat area (sq m)
S2 = 3060.00e-4; |Horn segment 1 mouth area and horn segment 2 throat area (sq m)
S3 = 3060.00e-4; |Horn segment 2 mouth area and horn segment 3 throat area (sq m)
S4 = 325.00e-4; |Port area
L12 = 23.00e-2; |Horn segment 1 axial length (m)
L23 = 36.00e-2; |Horn segment 2 axial length (m)
L34 = 28.00e-2; |Horn segment 3 axial length (m)
L36 = 28.50e-2; |Port axial length (m)
QdFo1 = 1.0;
QdFo2 = 1.0;
QdFo3 = 1.0;
|Parameter Conversions:
Sd = 1200.00e-4; |Diaphragm area (sq m)
Def_Driver 'Driver'
Sd=1200.00cm2
Bl=24.60Tm
Cms=1.66E-04m/N
Rms=4.35Ns/m
fs=29.00Hz |Mmd = 157.52g not recognised by AkAbak, fs calculated and used instead
Le=1.20mH
Re=5.10ohm
ExpoLe=1
System 'System'
Driver Def='Driver''Driver'
Node=1=0=9=5
Radiator 'Diaphragm'
Node=5
SD={Sd}
Label=1
Duct 'Below driver'
Node=0=9
SD={S1}
Len={L12}
Visc=0
QD/fo={QdFo1}
Duct 'Driver 2 port'
Node=9=10
SD={S2}
Len={L23}
Visc=0
QD/fo={QdFo2}
Duct 'Port'
Node=10=12
SD={S4}
Len={L36}
Visc=1
Radiator 'Port mouth'
Node=12
Def='Port'
Label=2
Duct 'Above port'
Node=10=0
SD={S3}
Len={L34}
Visc=0
QD/fo={QdFo3}
