I broke down... I bought this card for 250 euros. the design of the ultra-low noise power supplies and separate ground planes spurred me into action! What do the DAC pros think here... I'm not looking for the ultimate, I don't have the financial means... And I think it's still DIY, a bit qualitative all the same...
How many layers are the PCBs?
I will say this about Aliexpress or equivalent dacs (if that's what this is), which is that IME you don't get more than you pay for. Maybe you get less, though. Opamps and or passive components may be fakes. The main featured chips though, tend to be real. Film caps may be nonlinear mylar, not polypropylene. Ceramic caps are X5R or worse. Two layer boards may be used, when you need at least 4-layers. Stuff like that.
I receive this dac, normally on Saturday.And at the end of the day... it isn't your first DAC, so how does it sound in comparison?
Then wiring and box assembly, this is for me the part as interesting as the final listening.
A little comparison with my other dac, not necessarily fair, the USB cards are different as well as the number of channels.
Well, it's alive! Despite a big scare because of a rider... The translations from Chinese are hard to interpret. In short, the volume is thus found at full volume on a single channel... (test speakers) The speaker coil got hot, I still have the smell of it in my nose! But it survived, still 8 ohms on the multimeter. Hard wiring and testing on various modes 16 to 32b and 44 to 384 Kh in PCM, Dsd to check later... No noise or hiss at max volume! The sound seems promising, I loved the sound of the cymbals and plucked strings.
It's subjective, not definitive, I'll try after putting it in the box on my living room speakers...
. I can though understand the F aren't using "sauteur" LOL!
I' am a JUMPER,..
Imho those caps are not for sound, swapped them all on a similar constructor with 4493 dac. The difference in sound is just huge, but it is very difficult to choose a combination of different capacitors. It takes a lot of time.
As for my ears and system i've choose Nichicon FG for digital power supply, Elna Silmic II + Muse ES for VREF + VDDL/R + VCOML/R.
Very hearable place also in the power circuit of op amps...
Coupling or filtering capacitors?
This board can be modified as desired, nothing is finalized yet.
The SMD capacitor appears to be "Tantalum", the resistors "Melf".
I leave these in place.
Brief !
I welcome all (good) information, don't hesitate!
I'm about all KY electrolityc caps, here is a photo of my kit (don't smile how it looks, this is only test box)
- Digital Line Level
- AK4499EX
