I received my Aiyima A04. Have not swapped out the op amps, but really don't like how it sounds as is. Seems a little noisy/busy. Is this normal?
notakosan
What are you using as a Power Supply ?
The A04 does not tend to be noisy - Mine is almost silent using a Mean Well LRS-200-24 Power Supply (24 volts).
I am using this power adapter https://www.amazon.com/gp/product/B07C5P6NNS. Somebody recommended it along with the Aiyima A04. I am interested in Mean Well but a little hesitant to use it as external power supply.notakosan
Defo not noisy here.
Check PS...
Thanks for all the comments. I'll try other PS and see.
I'm using it with the power supply they sell € 18,21 25%de DESCUENTO | AIYIMA-Adaptador de AC100V-240V de 32V DC32V 5A, enchufe de la UE, EE. UU., 5,5x2,5 MM, cargador de fuente de alimentación para amplificador TAS5613 TPA3255 TDA7498E
AIYIMA 32V AC100V 240V Adapter DC32V 5A EU Plug US Plug 5.5 x 2.5MM Power Supply Charger For TAS5613 TPA3255 TDA7498E Amplifier|Amplifier| - AliExpress in Aliexpres. Didnt like how it sound the first time I played music in it. Now is a diferent history. Is not noisy just the sound weren't that clean and detailed. CAUTION SOLDERING THE OPAS TO THE ADAPTERS mines are different and they are looking to the opposite side. Aren't As most of the pics published here.
Hope it helps
Hope it helps
Noisy... means there is a prob, Class D is very quite.
Not sounding great, is quite a different story. As reported, we found (to our ears) in direct comparison that the stock 04 was barely up to traditional 500E Class AB amps. Still good VFM, but defo not the giant killer some claimed it to be.
Once tweaked though, it plays in a complete different league. We lack direct modern amp competitors in the "mid-fi sub 2000$ bracket", so can't say for sure, but somewhere there would be our guess. We wanted to take the amp to a shop to find out in a direct comparison, but successive lockdowns have changed our priorities...
Claude
Claude
My apologies. I should have used a different adjective. I meant the music did not sound clean or detailed, like mentioned.
It's done. As mouser didn't have the elnas I bought nichicon. It sounds awesome. Thanks again guys. The 24k gold 🙂 is hand made is somebody is wandering.
notakosan I have the A04 and that exact $16 PS brick and it sounds great. Quiet and no obvious distortion. I'm running with Focal 2-ways and can barely turn it up because the speakers are fairly efficient. New opa1656 opamps going in next week, but it's seriously great as is.
Well done 🙂 Hope you'll be happy with it.
Looking at one of your previous photos, I guess you also on an Onkyo amp. Can you compare to it, tell us your feeling ?
Gilles.
Something like 10 years ago I bought the living room setup. Reading in a national forum I discovered how to make and affordable but good sounding set up. Those speakers were very appreciated then because their sound quality and affordable price. They are not longer avaliable. The onkio drives the speakers. The 1000w berhinger power amp drives a 3cm solid sealed wood car woofer I did back in the time. I thought the sound was good but now I see the aiyima sounds much better. 😕 I can see now how good the speakers are. Not as good as many here but I'm not as deep submerged in audio.
Hi Gsusay,
I haven't read this whole thread, but what is the capacity of the Nichicon?
Connected to pins 4 and 8 (v- and v +)?
I imagine we must respect the polarity?!?
I bought those:
UKT1V100MDD1TD Nichicon | Mouser Espana
Producto: Audio Grade Electrolytic Capacitors
Estilo de terminación: Radial
Capacitancia: 10 uF
Voltaje máximo DC: 35 VDC
Temperatura operativa máxima: + 105 C
Diámetro: 5 mm
Espaciado del plomo: 2 mm
Longitud: 11 mm
Careful as my opa adapter is not facing the same way as the ones here so be sure how to install it, although in my case, the cap goes in the same pins
Let me know if i can help you further
Capacitancia: 10 uF
Diámetro: 5 mm
Longitud: 11 mm
If I understand correctly, the negative of the capacitor on pin 4 and the positive side on pin 8, is that correct?
In our case both are 10uF and one is lytic, the other X7R.
To answer your question, the differences were in sound, clearly all tech and values combos didn't sound the same.
Please use the search function: we posted already in details on that regarding how much bypass (values up to 30uF), what caps tech etc.
The only thing that remained a constant and stable and added values regardless teh combo turned out to be the C0G 0.0082 Murata cap (that comes as addition in our case). Obviously having 2 identical amps and being able to compare simple add-ons /bypasses on the fly with our biwired LS was a plus that helped us determining what to go for regarding the 3rd amp we built. And to stetle the final specs of the 2 amps we tweaked, going for biamping 🙂
At the end we picked up what we liked most from a pure sonic POV, as fine tuning as all other mods were done. All in our humble opinion.
Claude
Claude
Reviving an old thread... not sure it is the right place to post this, but we have just performed what is likely to be the last mod on Gilles amps.
Provided you have only digital sources and a decent DAC / player with digital volume control, we have put together a 5$ volume control that is probably very difficult to best regardless your budget. An dit could of course fit inside the Aiyima.
If there is interest, I will post here, if not, then probably not the right place as belongs more in a preamp thread... or I just spare my time for my own projects LOL
Have fun
Claude
Have fun
Claude
Volume Control - Aiyima A04 Modifications.
Hi Claude.
Please post details of your volume control for the Aiyima A04 in this thread as otherwise it is likely to get lost !!
It is still a modification and I am sure of interest to all of us who are playing with the various generations of the Aiyima A04 / Tilear XZD-1752.
Many thanks. James
Hi Claude.
Many thanks. James
- Class D
- Aiyima TPA3251 Modification Build Thread!
