Any suggestions would be welcome.
I have an AIWA NSX-340 which has a 3 CD changer. On loading it has a look at each disk in turn but they do not spin.
I've proved that no voltage is reaching the disk spinning motor. However the head motor works as of course does the loading / disk change.
I've been dealing with a failing head in another Sony system (see the ARCAM KSS240a thread) but in that unit the disk spun for a few seconds before getting the No Disk error.
Is this likely to be a laser problem (I think it may be the same KSS240a)? I am reluctant to try adjusting the laser current in case that is not the problem and I trash a good laser which I could use to properly fix the Sony.
Chris
Chris
