AI Speaker Designer
Just for fun!
Can AI design speakers? Does anything inspire you?
You can access Stable Diffusion on Discord for free.
high_end_loudspeaker_ultimate_audiophile_in_a_room__listening_experiance_soundstage_imaging_ba...png
high_end_loudspeaker_ultimate_audiophile_in_a_room__listening_experiance_golden_ear_5_star__se...png
high_end_loudspeaker_build_from_aluminium_metal__imaging_bass_extension_sweetness_treble_award...png
high_endstudio_monitor_loudspeaker_shiny_aluminium_metal__imaging_bass_extension_sweetness_tre...png
  • hifi_loudspeaker_studio_monitor_ultimate_high-end__In_a_modern_room__isy_blurry_soft_deformed_...png
Reactions: Arnandsway
Nice - what were the prompts for above ?
it can come up with some ludicrous stuff - but here's some I just ran which almost look usable (can't get it to do horns /Karlson well)
I like the last one a lot. I might actually try to do that under-cut sweeping cabinet style but not sure it's easy to make without flexible MDF or casting molds.
The prompts are actually in the file name so if you 'open as new tab' you can see what I used. Just kind of random stuff. You can select the 'style' as an extra promt so I chose photorealistic.
I run a copy of stable Diffusion on my own PC, so I used that. I tried a few prompts but couldn't get anything really impressive. I tried just "speaker", but that only sometimes yielded a speaker. Being more specific with "loudspeaker" was better:
I tried asking for particular types of speaker, but very few things worked. For instance it doesn't know that a "2-way loudspeaker" usually has only two drivers:
It did manage to mostly generate tall speakers when prompted with "line array loudspeaker", and some of them looked like line arrays:
Various other specific prompts like "kevlar woofer", "dome midrange driver", or "fullrange loudspeakers" didn't give the desired output at all, although "horn woofer" produced this:
It does better with the less technical aspects, for instance "burr walnut veneered floorstanding loudspeakers" presented me with these extravagant things:
