Against all odds...
If someone were to propose a design that used:
Parallel Single Ended
Distributed load pentode connected EL34's
ECC82's:
One as cathode follower,
fed by 2 * voltage amplifier stages
Low speed SS rectifiers
Mixed AC & DC heaters
Almost everyone (me included) would critisise one or more elements.
What I'm describing is a "Union Research Simply Four'.
I repaired it yesterday and have been listening since. It's got deep bass and sweet mids and highs with nice imaging. It sounds perfectly balanced to me. Mind you, it has a big bank of iron under the cover, and as many have said in the past, it's the iron that makes the most difference.
I'm pleasantly surprised 🙂
ECC82's:
Heheheh. I think I should rewire Hept'AU7 with steel wires instead of copper. Oh, and replace the 6SN7 and interstage transformer with another pair of 12AU7s or something. Then come back here and tell all how the upgrade sounds better.
Tim
John, if you don't mind measuring the voltages on the ECC82s you may be in for a surprise...
If I'm not mistaken they use that valve with unusually low plate voltages.
I heard these amps too, many a moon ago and while it wasn't my cupper it did seem to get the knods from quite a few others present.
Cheers, 😉
Frank,
Anode of voltage amplifier: 154v
Anode of subsequent cathode follower: 309v
Didn't record the voltage on anode of first voltage amp.
Is this what you expected?
All,
This amplfier was only remarkable in respect that according to "forum advice" they'd done everything wrong. It was a good performer, and considerably better than expected. It was not outstanding.
