Aesthetics
From now on I do full size prototypes with scrap lumber and the tubes before I start to build the real thing.
Works for me:
My first scratch build (with a lot of help) the plywood mock-up was more a proof-of-position for the pieces; the design was already proven. It also removed aesthetic temptations from the layout. The meters were shown to be a conceit.
The eventual layout, dictated by the dual-mono character:
Once done, I went on to add to the final design what had been an intended theme from the time the 45 tubes were chosen, a reminder of antique radios.
Please excuse the dust😀
I like a well constructed classic tubeamp like yours and sgerus´s. It requires a fine sense of proportions to work though. The volume and proportions of the base should be harmonic, and either balanced by or contrasting the tubes and trannies. Actually I liked your plywood prototype better for these factors. The Transformers larger volume is given more space so the tubes balance it better there. Also the base seems more square and lighter.
Well thats my two cents anyway, to balance out yesterdays wild ideas.
Here are some examples of what worked, what didn’t, and what I would do different next time.
Amp1:
This was my 2nd best looking amp. Doing it over I would use 10ga Alum for the top plate, the 18ga steel looks cheap.
Amp2:
Didn’t like this one from day one. Wrong proportions. No more hum pots exposed like that. No input cables on the top of the amp (that’s if the aesthetics win over engineering!)
Amp3:
Crash and Burn on this one..what more can I say!
Amp3_Rev2:
Better, but still didn’t like, Wrong proportions, didn’t like the tube layout, too much lumber exposed on the top of the amp.
Amp4:
(see post#44) My best looking amp so far… doing it over I would make a little deeper and get rid of the big oil caps (again, if the aesthetics win over engineering!)
To summarize:
Use Alum for the top plate… You can make holes with greenlee punches, it’s just the right thickness to mount octal sockets underneath and counter sink the screw holes.
Try for a 1:1.6 ratio for the size of the amp
No screws in the top plate other than the ones that mount the sockets or the iron on top on the amp
Pay attention to the tube and iron layout, including from the height prospective
I'd be happy with all of the ones you posted, but that's just me 😎 Great work...
Unlike the architects posting earlier, I´m a Industrial designer and academic in design. Form should obviously function but FORM FOLLOWS FUN.
Therefore I present to you: ELECTROLUV
Now that's design! and if it doesn't pass WAF build an extension to the house.
Well, we've just graduated design 101 and are taking the next course... But that's where it starts to get tricky! Preferences come in a lot more than right and wrong. It's easy to make something look bad.
I personally hate the steampunk stuff! What's the point?!? Celebrate a horrible choking black lung disease ridden time in our history? As far as the aesthetics of it, it's overly complex for no reason (a lighter w/ 20 gears on it?). Have you seen the steampunk cell phone? Might look good in a gallery, but I wouldn't want to use the thing! You'd probably cut up your face. (but, the style seems to bet getting popular so Im probably in the minority here)
I do like the slick mid century sci-fi looking gear, but again, I can see where others would think the black gages and knobs and aluminum panels is stark and dated.
Also, I'm guessing industrial designers would want to design things that will look dated in 5 years time, so people buy the next one!! (sorry, trying to be funny, not a personal shot or anything!!)
Now this is a good discussion; there are several established styles of designing tube amps. Aluminium ss look, gray or black with dials and utilitarian engineering look, untreated aluminium chassis pulled-out of a guitar-amp look, wooden base and alu. top classic look, deep gloss black and chrome and lots of tubes look. I think all of these are beautiful if they are well proportioned and with a good eye for detail. But I wanted to challenge your creativity and sense of product semantics a bit. There are lots of ways of expressing the qualities of amplifiers by doing things with materials and finishes. It will help our wives appreciate our abilities and increase pride of ownership. I totally agree that Steampunk often lacks authenticity and staying power as a style. It is often applied instead of integrated with function. But some of it is well integrated with function, interesting and thought provoking.
How about a game?
Lets think about what type of chassis aesthetic best fits the characters of different tubes and topologies:spin:
The wood with alu plate I find fits great with single ended tubes 45/2a3/300b/EL34 etc. And most EL84/EL34/KT88/300b etc pushpull too. Even if it is very common. It's not common in your average family home and I continue to find it attractive. But I can understand why folks think it is boring.
Here is by the way Kudret's Seth one of my favourites because of the copper hammerite and zebra wood.
But for my GM70 SE amp...I am leaning towards a tower type setup.
Bas,
very nice and classic... and with individual touches because of the zebra wood and hammerite..
Though I am with trondareo in terms of proportion: The top plate is way too thin and the wooden frame a bit too small... it doesn't look as if it can take the weight of all those transformers 🙂
How about this one for a wood classic...?
My first effort -->C3G headphone amp with 8mm top plate, no visible mounting bolts, root veneer over cherry wood. Psu to the left please, signal incl. output caps to the right.
Wow that looks amazing....almost unreal.
It is very real... 😉 though I also do CAD rendering (see my post at the beginning of this thread).
Underside looks like that
That is kind of the current status after many changes and tweaks (being a beginner then I had hum issues because of my wiring, later I replaced all e'lytics with MKP, put Oscon in the cathode and so on). Sounds quite nice now with, and C3G in triode mode is veeery fast and sweet in the highs without being overly bright.
One thing no one has mentioned yet is the look of iron. Good looking tubes and good looking iron makes a good looking amp, that is, if you don’t mess it up with the chassis. No jewelry needed. Some individuals, like most animals, are always attracted to shiny surfaces though.
A discussion about aesthetics is a silly thing anyway, entertaining maybe but totally useless. No democracy here, either you have it or you don’t.
Same with discussing music… pointless. Either you get it or you don’t.
One thing I love about science is that it either works or it doesn’t. 🙂
