Last time I did loudspeaker simulations on a Mac was with TopBox on a PowerMac 7200 running OS 7.6 or 8.1, I did a inital run with AENEAS with Eminence PA driver using different boxes and tuning frequencies. Great Fun I am playing around with two telescopic ports! I have a question with regard to the "Max Linear SPL @ 1m" I get an asymptotic slope from 200 to 10 Hz. With a vented box Max SPL should peak at the tuning frequency where the port works the most and reduces the output from the driver?
Having a proper program so parameters and projects are saved are really nice after running on line versions 🙂
support for multiple drivers in a single enclosure would be fantastic!
I've put this on the wish list. Hopefully this feature will be implemented this summer.
@DrBoar: I'll verify it. AENEAS calculates a Max. SPL that is limited either by the linear(!) voice coil travel or by the max. electrical power the voice coil is capable of.
Can't load files !!
Hi Raphael,
Thank you very much for this Mac software (at last !!!), I purchased it and so far it seemed to work fine. But lately I came back to my DIY projects and found that it now seems impossible to load drivers files, it always comes back to the default Visaton W170s. I'm trying something with a Dayton Audio PS220-8 ; I can save the Data, but can't open the file afterwards... Any thoughts ?
(I'm running MAC OS 10.13.2)
Thanks !!
Cheers from Paris, France,
And a happy new year yo you all !!
Bernard-Pierre Casanova
Hi Raphael,
Thanks !!
Hi Bernard-Pierre.
I am so sorry. I did not see your reply. Sorry, sorry sorry.
Is the problem with loading driver files solved meanwhile or does it still not work for you?
Did you update your MAC OS and since the update it did not work anymore?
Raphael
Raphael
Excellent, i am a big Mac fan, missed this thread as it started when i was in hospital… once i dig out my credit card i’ll try it out. I currently have a G5 PowerMac i keep around to run MacSpeakerz under OSX 10.4. If this works as well i will only need to find a web editor and i can retire that machine :^)
dave
dave
well, yes but it lost a bit the focus. Not many support requests, maybe one in the past two years.
And almost no feedback. So any feedback is welcome. Just let me know what you think that could be solved better or which features your are missing. That will be my motivation to continue with it.
How do you edit crossover workbench.
Like I’d I make a mistake running a wire?
How do you turn items 90°?
Delete it and redraw it. Components you can rotate with right-click.
I run version 1.4.1 and I can't find a way to create a new driver getting a blank slate instead I have to edit the latest driver loaded and then save that one with new name and paramters. I am missing something?
Well that's exactly the way. A blank driver doesn't make sense, because AENEAS always needs a valid set of data. That is the reason, why the Visaton W170S is the default driver.
Hi Raphael,
is there some kind of manual available for AENEAS? Might be in english, german or french.
I'd like to design a bass reflex loudspeaker with a RFC driver I already own, and don't know how to provide the T&S parameters to AENEAS.
Thanks for providing a macOS app.
- Design & Build
- Software Tools
- AENEAS: Loudspeaker simulation on macOS and iOS
