Hello All,
I have came across couple of speakers and want to create some kind of DIY speaker build and i need some advice on the design.
speakers that I have are:
2x AKAI 30W-A3, Max 130W 6.5 Ohm (552c045)
2x DMT-3038
2x Pioneer P77CP60-51D, 6 ohm, DT- 8202627
4-8 ohm impedance
IMG-20180218-112617 — imgbb.com
IMG-20180218-112624 — imgbb.com
IMG-20180218-112631 — imgbb.com
IMG-20180218-112651 — imgbb.com
IMG-20180218-112737 — imgbb.com
https://ibb.co/st5jC30
https://ibb.co/1T3ncPQ
https://ibb.co/VNzFD0W
https://ibb.co/pbPyYB6
https://ibb.co/PDGJ7zD
https://ibb.co/Wcs2Zj1
https://ibb.co/pzTWnPH
https://ibb.co/QNgznFc
https://ibb.co/w4T6RpQ
https://ibb.co/wggnPQ2
Thank you ..
2x DMT-3038
4-8 ohm impedance
Thank you ..
Greets!
Unfortunately, without someone already having done it, first measuring the driver's various specs is required to design a new box alignment, which may [not] perform any better, so for now all I can offer is for you to calculate the net volume [Vb] of the box it came out of and reproduce it in some other material; otherwise: measuring t/s parameters - Google Search
GM
GM
