Advice needed: 0.47 uF film cap DC for tube output
will be an anode follower with CSS. (T. Loesch circuitry for TDA1541A)
I have a doubt about Metalized MKP but read the Cornell Dublier had not this climbing light many MKP have. Loesch used to use tin foil KP for that // silver Mica of a lowest value !
Styren and maybe the ERO KP (non M) are more on the dark side (less colored) as well
what ever I choose it still stays less than 10 euros !
For WIMA, MKP is vacuum deposited metal on film only. FKP is true metal foil, if you go for the FKP1 then you get double sided plastic metalised film between the foil connected in series so more current capability. FKP4 is the same but single sided metallised film.
FKP1 is £3.33 for 0.22uF so for the performance it's a hard act to beat.
