Adjusting Discrete Class A buffer for gain?
Hi all,
I've currently got this http://myweb.tiscali.co.uk/nuukspot/decdun/gc/ls.buffer.gif circuit as a buffer in a basic preamp/source selector box. However, I've found that some of my sources (notably the Very Simple Phono Stage and my portable player) can't supply sufficient voltage and/or current to make the most of the amplifier.
Thus, I'm wondering if it's possible to modify this circuit so that rather than providing unity gain, it provided a modest +6dB or so, as a stopgap solution until I get around to building Rod Elliots discrete preamp (the DoZ Preamp).
Thanks everyone,
Chris
Thankyou for your honest and simple answer!
OK, in another question - are there any circuits of a similar complexity that I could perhaps reuse some of the parts in? I'm not after perfection, as I said, it is merely a stopgap until I can afford to build something of higher quality.
Chris,
You can quite easily change that buffer circuit to provide some gain by adding one PNP transistor and a couple of resistors. It's called a complimentary feedback gain pair, or words of similar meaning.
The problem is that I don't have a schematic in electronic format to post - or a working scanner - but if you can give me a fax number - I can fax it to you.
Regards, Allen
Chris,
You should have the fax OK by now - it went through from this end at least.
The circuit has been used by all sorts of good audio companies (like Revox) since the birth of time, or at least the birth of transistors anyway - and sounds OK.
I've been a tube guy for 25 years now, but was used in my last commercial solid state preamp.
But if you want to do the job properly, try this circuit for your new phono capable preamp:
http://www.vacuumstate.com/phono_secrets.htm
Regards, Allen
Chris,
The resistor at the collector of the original emitter follower NPN is 680 ohms.
The resistor (Ra) from the emitter of the original NPN to the negative rail is the same number in kohms as your negative supply is in volts. So if the neg rail is 15V, then this should be 15k. If 20V, then it needs to be 20k.
The resistor (Rb) from the collector of the new PNP to the emitter of the original NPN is the one that sets the gain of the overall gain block, by the formula:
Gain = (Ra + Rb)/Ra
So for your desired 6dB gain, Rb will be something like 5-6 times bigger than Ra.
OK?
You may have to tweak the original transistor's 680 ohm collector resistor to get the collector of the PNP to sit somewhere around zero, which allows you the most linear output swing.
Regards, Allen
