adjustable XO / amps ?
Be gentle with me, I haven't searched very hard but that's only because I don't really know what to look for.
I'm excited by the idea of building different speaker designs but a little daunted by the XO design. Plus my personality is such that I don't like to set things in concrete but prefer to keep things flexible.
What I want is an adjustable set-up that I can quickly attach new speakers to and try them out. At first I'll be experimenting on just the L and R channels of the 5.1 output from my AV amp but later may expand to include centre and rear channels.
Starting with a 2-way speaker design, I'm thinking of a single box per channel which allows me to adjust the crossover frequency, and adjust the gains of the split signals, and then power amplifies them (3 dials on the front).
Is this at all sensible/possible. If so, I expect it's been done before?
Or is their some other way to do what I want?
TIA, Jim
PS. What sort of power split is typical for a 2 way design, ie would the 2 power amps be the same or would one be bigger than the other?
most designs for adjustable power supplies involve adjusting resistors via a potentiometer. some designs have more frequency dependent resistors then others. other designs will not retain the desired Q as resistance changes.
the most flexible design would be a DSP algorithm, as you can set all the parameters to exactly what you want.
another method to do what you want involves digital potentiometers and a microcontroller.
the lower order the filter the easier it is to design.
look into subtractive crossovers as well, as they can help simplify the design by requireing you to only make a lowpass.
generally the power supply is the same for convience and peak power -- a highpass can theorerically require 2x normal peak voltage (on a square wave). unless there is a real capacitor on the output that can charge to Vcc, you would have to simulate one...
I've been looking at all the gainclones out there, very nice many of them are and it makes me want to build something stylish as well as functional. So I'm happy that the power side is inexpensive and quite easy to do.
If I'm going to build general purpose amps for each channel they should be 3-way I guess. Which if I have understood means 1 transformer, 1psu kit, and 3 amp kits per channel. Which looks like it'll cost about 100USD plus box, connectors, switches.
Now I just need to understand the crossover/dsp bit. Should I go to the speaker area for that?
6 channels
I'm going to have a go at using a dcx2946 to give me my 6 filtered channels for the 2x 3-way speakers.
So that means I want to build 6 channels of amplification. One decision I'm having trouble with is how many transformers and how many boxes. I want a nice clean layout with good separation of psu and amps (separate compartments if not boxes). Also I want course stepped attenuation on each channel (because I may need to use high levels through the dcx).
My favoured options are:
3x 2ch amp with 1 transformer in each box. These boxes could have many other uses, and are easy to design nice and symmetric.
2x 3ch amp with 1 transformer in each box. This is a neat match with the intended purpose of driving 2 3way speakers. Gives the option of locating the amp with (inside) the speaker later.
1xpsu , 2x 3ch amp. A 3 joined box design could look very smart, unfortunately it'll be sitting under the dcx so maybe I shouldn't be aiming for great looks).
What do you think ?
What sort of wire/connectors should I use between psu and amps?
I'm thinking of plate aluminum designs but someone said al was not good for RFI, so do I want steel box with al for the heatsink only?
Jim
I gave a lot of thought to a similar project and finally decided that I would use 3 dual mono amps with each channel having it's own PSU (in the amp housing).
Of course this is the most expensive option but whatever you decide on will have to take cost into consideration! 😉
Nuuk - Ah so you are the decibel dungeon. I have read quite a few of your pages. Did you actually build an active 3way speaker?
I like the looks of your wood tube monoblocks, but don't you have to veneer your CD player to match?
I'm pretty decided now that this first project will be 6 channel in one box. The box will be functional rather than pretty (probably stainless steel as I can get that fabricated for free). 1 or 2 transformers will sit in the centre compartment.
Is there any advantage to putting each amp in it's own compartment ? Or will 3 of them share the same space happily?
Big unknown for me is heatsink. Can I just screw each amp to a piece of al angle, and screw that to the steel box floor? Or should I put each amp on a thick piece of al which is also an external wall?
hmmm, I may have changed my mind already. If I can get small neat looking boxes made, then 6 monoblocks could be good. You can't get more flexible. I could build an A/C power strip with 6 power plugs on it that each monoblock sockets onto (otherwise I can see that it will be a full time job keeping the 6 blocks neatly lined up)
Richie - I will take a look. I don't yet know what is meant by a MOX active xo. My target is easily adjustable xo ( by easy I mean stand up, twiddle a knob or pot, sit down again - not swap resistors etc).
My aim is to be able to experiment with drivers and enclosures without having to understand the workings of crossovers.
And using DSP I'm expecting that the xo design tradeoffs will be removed (not that I know what the tradeoffs are!).
Jim
That's right, and just down the road from you in Burnham-on-sea (and not too far from Richie!).
No but I was considering a three amp set up for my current speakers (TL subwoofer, full-range and tweeter).
I have considered a makeover for the CD but it would be a tricky veneering job with the rounded edges. Perhaps solid wood for top and bottom and veneer for the front!
I have found my LM3875 amps to run only luke warm. Even the LM3886's don't get very hot. It depends how hard they ahve to work but if you can get a big piece of angle and add a PC heatsink for each chip you should be fine, specially if you put vents in the base and top of the case.
Those cylindrical enclosures are not too difficult to make! You could paint or veneer them and if you can find somebody with a lathe you can easily knock up the front panels 😉
Design 1.
OK, I think I can do cheap, easy, flexible, and good looking in one design. (except maybe cheap as it uses a transformer per channel)
The design uses one thick aluminium side wall. A 4 sided bent up steel box, and all components are attached to this wall. Any number of these can be joined to each other with a final side wall to finish the amp.
One possible drawback I see is that the heatsink/sidewalls are not external walls. But I suppose that's why you make holes in the top and bottom of the box.
The simplest box would have a front psu compartment, and a rear amp compartment. This means the 240AC passes through the amp compartment, and the front mounted attenuator wires pass through the psu compartment.
What do you think?
Jim
Oh yes. What is the definition of 'monoblock' ???
Design 2.
Cheaper than design 1. If i'm building a 'power strip' it might as well be the psu!
Buy 3 stereo kits.
Mount the 3 psus in one box 420mm wide by 60mm high.
Build 6 1sided amps per design1. Join them together for 420wide x 120high x120deep.
I like this!
Only drawback?? is that interconnect and speaker cables will be passing above the toroid. Is that a problem ?
Jim
Is a Gainclone really a Gainclone if the psu is not separate?
Cool 🙂
They look nice, but not for me. I'll stick to black and silver.
At the end of the day any design like this is a compromise. Separate cases for amps and PSU's are good but then you have the umbilicals and all the plugs and sockets.
I built my last couple of GC's on what I call H-frames. Imagine looking at the chassis from the front and it looks like a squat letter H. That gives quite a bit of room for amps and PSU's (and I included buffers in mine as well!). The H could be made from wood, as mine was for prototyping, or metal.
For your project three transformers could go above and below the centre shelf at one side, leaving plenty of distance between them and the amps at the other end. Or you could put the transformers in the middle and just three amps at either end (depends if you are inluding volume control etc).
I'm quite happy now with 1socket and 1plug per channel, direct connection with no cable. Plus a single 240v to the psu. That beats having x6 240V leads.
Do I need buffers? what do they do?
Each amp will have a 6 or 12 step resistive attenuator. To bring down the likely high output from the dcx.
Actually, I've lost track. When I see volume knobs on the gainclones, do those cut the input signal or do they adjust the gain of the amp section?
Jim
I was referring to the voltage rails rather than the mains supply.
Not if you are using the active crossover close to the amps.
You should use a volume controller after the source to control the volume level. If you keep all the amps to the same gain, then you shouldn't need a volume control on each one.
Yes, I realised. I've ditched the single box design for the moment, so now I'm comparing 6 monoblocks(?) to 6 amp boxes which plug into a single psu.
[/QUOTE][/B]
I haven't firmly established that I will need to attenuate all the channels. But if I do, having a variable attenuator per amp seems flexible for future uses? Certainly better than an extra 6way attenuator box.
You can find all about the MOX here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=27651&highlight=
It is easily adjustable and can be implemented with pots or/and several multiposition switchers.
I will read, but it's a big thread.
How much time and money will x2 3way XO cost?
As a beginner, the dcx for 400USD seems the best route.
Must remember, building speakers is the target not XOs. I have stayed too far into amp building already!
In any case the cost of a 3way XO should be much less than $400, depending on the local market. But if the xo is not your main target, then it might be best not to fiddle with the MOX and buy the DCX. The MOX may be time-consuming for a beginner although it does sound, at least in my opinion, superior to the DCX.
Regards,
Milan
