Adjustable Fixed Grid Bias
Hi Doug,
How about variable plate voltage as long as you stay within the allowable dissipation limits this might work well enough and prevent drain on your bias battery with the potential risk for mischief that entails.. 😀 I've never tried it so I can't really say how well it would work, but for limited operating point tweaking it should work ok. (Anyone using a plate load ccs with fixed bias is implicitly doing the same thing any time they swap tubes.)
