idea:
Use a crystal with n x frequency that is needed for the used os filter.
Feed it into a n stage decimal counter.
Feed n os filters, one with each counter output.
Feed n DAC chips, one with each os filter output.
Parallel the I-outputs of the DAC chips.
Any good ?
Okay, we need n receivers also, maybe...
Will it reduce not only noise and distortion of the DAC chip itself , but also negative effects of jitter, induced by the chain receiver- os filter ?
idea:
Any good ?
