Adding Volume Control / Bass Cut / Bright Switch to mono TPA3116D2
Hi all,
I'm making a guitar "pedal power amp" as a bit of an experiment after years of making Bluetooth speakers using the commonly available eBay class D boards.
For this project I'm looking at this XH-M542 board:
https://www.ebay.co.uk/itm/194520940446
I know it says 100w, and it likely isn't, but that doesn't matter. As long as I can get say 30w at least from a 24v/3a PSU, it'll be fine.
My first conundrum was adding a volume control. I can't remember which thread I read on here, but I arrived at a simple 10k log pot on the input. I think that was chosen as the input impedance of the amp is also 10k? I could be wrong.
My next hope is to be able to add a couple of extra switches to the pedal to give a couple more sound options.
I'm thinking a bass cut switch to roll off some low end and tighten up the sound a bit, and then a bright switch that allows some treble to pass the volume control when the volume is turned down. These are also called "treble bleed" circuits and are found on guitar volume controls a lot, as you may know.
So my question is what values will the components required need to be, and how they will be connected up in relation to the volume control.
Any help/suggestions will be most appreciated!
Jim
To clarify, I sort of know how these circuits would work in a guitar - I can get schematics for those online already. However, I am assuming that the values chosen will be specific to a circuit with a guitar pickup and the typical 250k or 500k pot. What I'm wanting to know are the values needed in a line level circuit that uses a 10k pot (if indeed that is the correct selection). 🙂
