Adding second bridge to integrated amp, good idea?
Hello,
I have a rotel intrgrated amp that I have modified quite a bit.
The pre-amp section of this integrated shares the same bridge and power supply filter caps as the output section.
Would it be a benefit to use a dedicated bridge and filter caps for the pre-amp section?. I would still be using the one transformer.
My thinking is that there would be less of an influence on the pre-amp supply voltage if I did this.
Has anyone tried this or have any input?
KevinLee
