Hi
I wanna know if its possible to add pre amp option on my Ld i+ hybrid headphone amplifier by increasing the output impedance(say 15k registor) and with a output switch?
Because preamps output impedance should be higher than HP AMP output impedance right?
I might try without adding Registors, if its sounds distorted ill alter the output impedance.
No. As long as the source is at least 10X lower than the load, you're good. An HP amp can also be a preamp, but not the other way around.
You would only need resistors to absorb power (like connecting a speaker output as a preamp).
You should be good to go.
