JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Here is the schematic.
Can I replace resistors R35 and R36 to 200 ohm multi-turn trimpot? Is there any disadvantages?
What you might do is perhaps change those resistors for two 50 ohm types and add a 100 ohm multiturn pot. You could zero DC and still be safe with the resistors.
Carlos
