More and more modern receivers & processors are doing away with multi channel analog inputs. I wanted opinions on best way to add those inputs. Would after digital analog converter be best place on each channel? What would be best wire to use? Would it need attenuation? Source unit would be multi channel Blu ray or Dvd player. I had planned on doing this and using either relay externally powered or simple switches to engage circuit.
