Hey, I have a question for you regarding an amp of sorts. And I am fairly handy but am not what I would call knowledgeable about electronics.
I just got a Yamaha Clavinova CVP-7 (for free!). It was made in 1986. The keyboard (76-key) is great, the cabinet is great, and the built-in 30wx2 amp and speakers are great. I love the idea of just siting down and turning it on as opposed to setting up a keyboard on a stand, plugging in the pedal, hooking up to an external amp, bla bla bla.....
BUT...the one weakness of the 1986-era piano is the 1986-era sounds. The piano is, well, 1986. It won't fool ya, unlike these awesome new ($$$$$$) Clavinovas.
So, my solution is to buy a Kurzweil MIDI module and use the sounds from that, which I know will be great. The thing is fully MIDI-able and the implementation charts match up for the pedals, etc... The Kurzweil is a little 1/2 rack with feet and even a front power switch so it will just sit unobtrusively right on the piano lid.
Here's the thing: The Yamaha has no line in, and I want very badly to output the Kurzweil module back to the piano's built-in amp. I want a self contained unit, you know?
So....can I add line ins to my Clavinova? Would it be as simple as tapping into the master volume, running from the hots to the hot pins of a set of RCA or 1/4 inch jacks, commons to ground, and installing the RCA jacks somewhere in the panel of the Clavinova? Maybe using a DPDT switch inline to switch back and forth between the internal sounds and the Kurzweil module's outputs (this is all stereo, by the way). There are RCA line out jacks on the Clavinova's panel and I would be willing to cannibalize those as I can not for the life of me see myself using the built-in tones for recording, ever.
If you have any thoughts let me know. Thanks!
I was able to address this. The power amp section is a completely separate board and I was able to remove the piano lid and trace the cable that runs from pre to power amp. I'll simply jumper in there and add a set of jacks and I'm all set.
Or maybe not. I realized this would not address the issue of using the external module's sounds through the headphones, which I really want to be able to do. So I need to go in somewhere pre-headphoen jack. I guess I'll give the lid another lift and have a look once more.
I saw yours on Craigslist, it looks like you have given up on it, which is sad. I love this piano. I have gotten very attached to it and even more so lately.
I did solve my issue; I wound up making a cable that connected to the preamp in, and adding a jack to the underside of the piano for the line in. Best of all, the external MIDI program patches can be controlled by the piano, the Stereo Symphonic still functions, as do all the rhythyms. The only thing that does not work are the bass and chords which I did not really use anyway. The work is 100% reversible as well. The volume is controlled by the piano's master volume too. My only other enhancement might be to set up the external MIDI synth to power on and off by way of the CVP-7s power switch.
This thiing is essentially a primitive computer; it would be hard to solve your issue, I am guessing. Someone with experience in repairs of this unit would probably be the only one who could help.
I do have the service manual and would be glad to send you a copy.
Hi, I too am working on a cvp 7. If that service manual is floating around, I would GREATLY appreciate a copy of it. My email address is CHRISR7ten@yahoo.com, but that word "ten" is actually the number ten. I was a Yamaha tech for several years, perhaps I could contribute to adding that line in, esp if I had a service manual.
As far as that keys 'overloading' issue, I have never seen that per se. But I have seen many boards that the physical force of pressing many keys at once, or pressing them hard, causes a loose component or a component with broken solder, to work loose, and lock up the unit. I have found that components attached to heat sinks: voltage regulators, transistors, amp ic's, tend to be have broken solder and are often the culprit. That's my 2 cents! You can see if just tapping on various areas also causes it to lock up!
Anyway, if someone can send me the manual, that would be great!!
DinoBob
How can I go about obtaining a copy of the tech manual for the Yamaha cvp7 from you? I have two of these instruments but one has a problem with lack of audio from the speakers. The headphones jacks still have output but not the speakers. I also have a CVP5 that has one side of the keyboard that does function. The manual would sure be appreciated and would be a great help in fixing these problems.
Thanks -- Allenbruce
Manual (link to pdf)
Yamaha Audio CVP-7 user manual - Owner's Manual (Image)
Found this when looking for the manual for my own issue. When I turn the power on I hear a click and then nothing. Any thoughts? THANKS!
Yamaha CVP-7 Manual
Hey Dino!
I'm new to this forum and I saw your post about a Yamaha cvp-7. Your post mentioned that you have a service manual for this keyboard. Somebody is willing to give me one of these keyboards but it has one dead noteper octave. I don't need to collect anymore irreparable stuff, but if I can fix it, I might be interested in the unit.
My question is, do you still have a copy of the service manual that I could possibly get from you?
Any help would be appreciated. I'm not sure how to give you a e-mail address throouh this forum. Perhaps you can school me on that subject as well.
Thanks,
jdg614
Hey Dino!
Thanks,
jdg614
hi takkajack here im a newbee so hello to all. can anyone help me with my cvp7 clavanova. when i press the keys the sound is fuzzy and distorted. i got a service manual thinking it might have a problem solving page but no. if anyone can help i would be really grateful thank you terry
service manual for cvp-7
hi. i recently have aquired a CVP-7 digital piano and am in DIRE need of service manual. PLEASE if you still have available could you send to brog901atoutlookdotcom ...... thank you.
CVP-7 Service Manual
Hey gang - saw that a couple people here had the service manual for this beast. Can I get a copy of it? I just picked one up from someone in the neighborhood who was giving it away, they said it had been working fine but one day the sound generation died. Amp seems to be working, but no lights on the keyboard tone selection. She said her kid had been switching the power button on/off repeatedly when it died.
thx
Rob
thx
Rob
- Live Sound
- Instruments and Amps
- Adding Line Ins to Yamaha Clavinova CVP-7
