adding a capacitor to a FR speaker
I'm building a portable small speaker system and I want something to do these things and I've been reading that a capacitor could do it. (but some disagree so I don't know what to do.)
1. Limit the low signals (-6db) below 120 hz going to my L/R speakers.
2. When and if I add my expensive small woofer, then I would like to limit really low signals under 40 hz.
3. I also think getting rid of the lower frequencies will allow me to turn up the volume since the speaker will not being hitting its xmax as much - true?
If a capacitor can do that, what site is best to figure the value?
I'm also thinking that a capacitor to the woofer, if large enough, might provide an extra boost of current during low bass passages? What are the opinions about that?
Thanks that is a good site. I went to it but I'm wondering: Do I enter the ohms of the speaker, the RE, or should I look at the impedance graph of the speaker and see what the ohms are at the HZ that I want to start the slope, ie 120hz?
Do you think you have the time to answer the other questions?
thanks
sure thanks
Fountek FE83 3" http://www.parts-express.com/fountek-fe83-3-full-range-driver-8-ohm--299-020 Power Handling (RMS)12 WattsImpedance8 ohmsFrequency Response100 to 25,000 HzSensitivity85.7 dB 1W/1mVoice Coil Diameter0.78"Thiele-Small ParametersResonant Frequency (Fs)122 HzDC Resistance (Re)6.5 ohmsVoice Coil Inductance (Le)0.66 mHMechanical Q (Qms)2.36Electromagnetic Q (Qes)0.88Total Q (Qts)0.64Compliance Equivalent Volume (Vas)0.03 ft.³Mechanical Compliance of Suspension (Cms)0.77 mm/NBL Product (BL)3.6 TmDiaphragm Mass Inc. Airload (Mms)2.2gMoving Mass Of Diaphragm (Mmd)2.1Maximum Linear Excursion (Xmax)3 mmSurface Area of Cone (Sd)28.27 cm² Tang Band W3-2108 3-1/2" RBM
http://www.parts-express.com/tang-band-w3-2108-3-1-2-rbm-micro-subwoofer-4-ohm--264-949Nominal Diameter3-1/2"Power Handling (RMS)25 WattsPower Handling (max)50 WattsImpedance4 ohmsFrequency Response45 to 1,000 HzSensitivity77 dB 1W/1mVoice Coil Diameter1.25"Thiele-Small ParametersResonant Frequency (Fs)45 HzDC Resistance (Re)3.6 ohmsVoice Coil Inductance (Le)0.21 mHMechanical Q (Qms)4.67Electromagnetic Q (Qes)0.51Total Q (Qts)0.46Compliance Equivalent Volume (Vas)0.06 ft.³BL Product (BL)6.17 TmMoving Mass Of Diaphragm (Mmd)17.96Maximum Linear Excursion (Xmax)7 mm
thanks
Online crossover calculators are essentially worthless, taking no account for impedance as it varies with frequency & thereby affects the behaviour.
A 1st order electrical high pass will roll the driver off (assuming a constant impedance, which isn't the case) at 6dB/octave & is -3dB down at the nominal target frequency. Not very much protection, but some. You'd need one for each channel of course. Eliminating <40Hz signals really needs an active filter; technically it's possible to do it passively, but the complexity, insertion losses etc. involved make it impractical.
