Add Series Resistance of the Wire in TS measurement?
I have just completed TS measurement for my woofers (10R Resistor in series with the driver). My woofer has a DC resistance of 6.8 ohms but the wire connecting it to the signal generator adds anonther 1 ohm. Do I add this to the DC resistance of the driver?
In my calculations I have added the series resistance of the wire and the validation of sqrt(f1*f2)=Fs for the -3dB points agrees very well.
the sqrt f1 f2 test is just a test for peak symmetry (or asymmetry caused by high VC inductance), Re does not affect it.
If you are doing the constant current method of T/S parameters measurement (big series resistor), the impedance of your cables doesn't matter because you are "calibrating" with a 10 ohm resistor, and using Re and Zmax to calculate Ro.... and so on.
