W Wagener Member Joined 2004 2004-04-02 8:44 pm #1 2004-04-02 8:44 pm #1 If I want to run a 4-channel leach amp into car speakers (4-ohm) do I have to add more output transistors or is this not necessary? A azira Member Joined 2003 2004-04-02 11:13 pm #2 2004-04-02 11:13 pm #2 The Leach Amp is pretty beefy as it is, unless you plan on running it pretty hard, I would guess that you'll be fine. Most car speakers (subs excluded) won't be able to handle the max power of a leach. -- Danny Status Not open for further replies.
