Hello,
I am thinking of connecting the Out line from an audio interface to the power-amp with phone jacks to be able to chose between build-in pre-amp or the external interface.
Has anyone tried this?
Could this create any problem?
Do I need to build any input filter?
Thanks for the support.
The Idea is to make some kind of modeled combo with existing gear where I can test different guitar SW.
Since I need an interface for a mic, I Will try this solution.
You could use a cheapo 2 channel mixer on the input.
Even a couple of pots and a couple of resistors to mix the signals.
