Just received and built my nc122mp amplifier, in a ghent audio case.
For now, the amp is always on, but I would like to use a trigger input.
I'm not an electonic guru, so I'd like your approbation before doing anything ^^
I undestand that I have to deal with the ncore module H-bus connector.
Need to cut the J6.3 (PS standby output) to J6.9 (PS Enable) bridge, and add kind of relay that will be open/close according to the mono 3.5mm jack input?
My preamp doesn't have trigger output, so I'll use a wifi/IR outlet with a 5V power supply plugged in on it to trigger the amp.
Any recommandations ?
The simplest solution would be a master-slave power strip, especially if your preamp doesn't have trigger out.
I would prefer a trigger solution, to be able to both use standby mode and delay the amp statup, so that it should avoir "pop" noise in mys speakers on amp statup.The simplest solution would be a master-slave power strip, especially if your preamp doesn't have trigger out.
