add a subwoofer to my Proac super tablette
hi!
the QB3 alignment vented box is about 40 litres. the passive crossover air core coil is difficult to build because it's very big coil and may be increase R(ohm). but u can use steel core coil because it's lower R. the cut off about 100 hz that i often see.
hi zyfb
u can use passive xo calculator program for get the valve coil (mh) about 100 hz. when u buy if u want air core coil please choose low DCR. zyfb before u do please check the Sensitivity between proac and sub driver. these are not difference too much. zyfb u can use hi-pass filter order 1 for 4" proac@100 hz. u only use Con in series with 4" proac. if u want to check the respond frequency. i have free RTA to give u.
RTA
regard
TW
