Adcom GFA-585 HELP NEEDED!
I`ve been trying to get this amp running properly now for long time and it now seems that a previous repair was not done correctly, the zener diodes near the input that are Adcom specials, (look like transistor), may been replaced with the wrong value, the zener diodes left channel are d111,d112,d113 and d114, the right channel are d161,d162,163 and 164.
Does anyone know or can measure the correct voltage of these zener diodes for me so i can finally get this amp up and running properly.
Cheers, manly thanks from downunder in Australia, George.
Are you shure that they are zeners and not transistors???....is not usual so much zeners at the input of a amplifier...
As they are 4 for each channel it seems that they are a double diferencial (double LTP)...😉
Transistor/zeners
Possibly these are in fact transistors wired as zeners.
If you connect collector and emitter and apply a negative voltage (for a NPN) to the base, the device will act as a zener diode with a voltage appr. 5-8 Volts.
Arne
Guys, thank you all for the help, i`ve changed those zeners now, that i thought was the problem but the problem still exists, bugger! (aussie slang for sh--------------------------t!)
what i`ve changed so far are all the electrolytics, dc servos and those zenners, and measured most of the fuseable 10ohm/ 1mohm resistors on the advice of the old Adcom imorter here in Australia.
The problem that i`m still having is that there is too much current being pulled through R153 1.2k and R154 1.2k they get hot and start to smell,and the green leds D113,D114 in that same section, that their using as diodes are very bright compared to the good channel, but i`m getting good sine and square waves on the scope, and the bias is steady, however the dc offset is at 1volt! As you can tell i`m not a tech, but can usually fix things with persistance and help.
Any More Ideas as the Importer has none.
