I have a question about interfacing the AD1862 with a digital filter. The digital filter sends out BTC MSB-first at 11.2896 MHz, which I understand works fine with this chip. But since the AD-chip converts the last 20 bits after LE goes low, what happens if the dac is fed with a 24-bit signal? Is it mandatory to convert the signal to 20 bits?
Thanks for the reply
The signal is Two's complement, MSB first. The most significant bit is sent first, but these first 4 bits will be ignored by the dac. I guess this would give an error in the conversion, but I don't really understand how the AD1862 works to convert the input signal, so I might be wrong.
