Please post in english only.
Translated,
Hi Thomas,I have replaced the standard Opamps my KR P150 now also with LM4562NA. The result is so, as described by friends.Do have recommendations for further improvement
In short - ad846 is very hard to replace. This is a unique set of characteristics for the chip. Try to find the chip.
maybe through a discrete version - observe last postings from this thread:In short - ad846 is very hard to replace. This is a unique set of characteristics for the chip. Try to find the chip.
http://www.diyaudio.com/forums/soli...rete-op-amps-overview-wanted.html#post4183122
For the AD811 I miss the internal diagram - thus it is hard to believe for me, that this type is a replacement for all applications. The same is for the LME49713. The term "current feedback" means not automatically the same internal circuit.According to Analog this is a direct replacement:
http://www.analog.com/en/prod/0,2877,AD846,00.html
http://www.analog.com/en/prod/0,2877,AD811,00.html
Here's another excellent sounding chip!
Though it is a dual, it sounds great when properly 'tamed'! Otherwise, it can be a wild one! Use a 'scope when deploying this filly!
NJM2114 | NJM2114D NJM2114M NJM2114L | HIGH PERFORMANCE LOW-NOISE DUAL OPERATIONAL AMPLIFIER | Semiconductor | New Japan Radio(New JRC)
Any news ?In short - ad846 is very hard to replace. This is a unique set of characteristics for the chip. Try to find the chip.
Maybe in the meantime are released any replacements ?
Translated,
@Romcat
Yes, try the LME49720HA (metal can). I can't explain but it sounds so much better than the plastic version.
in the meantime there are various replacements, even from the internal schematics. Go to post #5 underIn short - ad846 is very hard to replace. This is a unique set of characteristics for the chip. Try to find the chip.
https://www.diyaudio.com/forums/sol...-sounding-op-amps-lowest-thd.html#post6528415
- Digital Line Level
- AD 846 replacement
