I am gathering data and advice on active xovers.I have been to a few sites and here is my current plan..
Seperate P.S.U (flat cap design)
either 12decibel/octave or 24
This bit will cause some reaction.......
Royd conn R's or Tannoy M1's????
The speakers are the only ones I have and one of them is to be used.
Through ideas at me and I will responed.(web sites)
Kieran
Kieran
I'm about to build one using the ESP project 9 (Linkwitz-Riley 24 dB/octave). See http://www.sound.au.com
Whilst you're at the ESP site, check out the links page... Specifically http://www.linkwitzlab.com
Simon
Simon
Kieran,
You mentioned a flat cap PSU design - do i take it you mean flatcap as in Naim?
Are you using the corssover with Naim amps, as they need some careful signal conditioning to maintain stability.
I can provide more info if this is the case.
Andy.
Andy.
