Given the stability of british mains, am I better off going for a toroidally wound
one? Farnell sell some too. Might see if I can get a suitable mu-metal surround
for it too, just for perfection's sake.
Am I right in saying I can wire the two 115V primary coils in parallel and get a 230V primary?
hi,
The shield is near pointless given the toroids lower field in the first place.
Two 115V primaries in series give you a 230v primary, I assume TIWYM.
rgds, sreten.
Sort of ideal, filters shunt the hash to earth whereas a lossy transformer just loses it in the gap so to speak. Also bear in mind have you actually had any problems with clicks and noises previously anyway?
No problems so far, but the old, buzzing transformer is an EI type, and I'd prefer toroidal to avoid any hum.
Toroids can hum and buzz and shake your chassis, much the same as EI.No problems so far, but the old, buzzing transformer is an EI type, and I'd prefer toroidal to avoid any hum.
It's the quality of manufacture that mostly determines the noise from a transformer.
The main exception that I am aware of is non symmetrical AC mains' waveform through EI or Toroid. The toroid does benefit from the addition of a DC blocking Network in the primary feed.
Right, I've gone for a line filter and toroidal transformer combination. And a switch, because unplugging was getting annoying. And a multimeter because this one's a pile of crap 🙂.
Disaster! The new multimeter (that came along with a shiny new 15-0-15 transformer) has revealed that the old transformer is in fact 12-0-12.
I can't use a simple potential divider, can I? I've got to buy another transformer?
Yes, new transformer is your only option.
The 15-0-15 one will come in for an overkill pre-amp or similar, or you may be able to return it?
Must be a teensy amp in those speakers!
Damn it. Reckon Farnell will take it back?
I have to set my software audio level to around 5%, and the quality is awesome =).
- Power Supplies
- Active Wharfedale Diamonds Transformer
