Active system converting to passive system
I'm looking into group delay and crossover design, will be väck with questions about this.
After looking more into the crossovers, might want to try another tweeter anyway but I'm not sure.
I'll still do the configuration in the active crossover till it's satisfying and then try to copy it.
The point is like mentioned before to bypass the active crossover for muds and tweeter to have a better and snd more simple signal path.
If delay comes in to the picture I don't know how to deal with it
Crossover
I have been thinking and thinking.
I think it's too hard to integrate those 2 drivers with a passive crossover.
I would like to buy a midrange with higher sensitivity that matches the amt snd test then with a active filter.
Do you guys think it's stupid to get an 8 " driver and crossover at +3000hz?
Rather get a high efficiency 6.5" driver?
I would also like to get another pair of tweeters for the midrange flexunits, should be really good quality, any recommendations around 93 dB sensitivity?
I was thinking about getting a finished crossover from beyma to try,
What do you think about that?
Suggestions :
Beyma T2030 2x Beyma T2030
Beyma T2030, Aluminium hi-fi tweeter, 15W, 8 Ohm, 95dB/w/m,
Beyma F 130 1x Beyma F 130
Beyma F 130, passive crossover, Type: Highpass, TX/over frequency: 3000 Hz, 300 W RMS,
