Active speakers.
I am looking at building a pair of mono gainclones and installing them inside my speaker cabinets to provide separate power for the woofers in a pair of three ways. Is there any reason not to do this? I am building a pair of 300b monoblocks but feel that they may struggle with driving 3 way speakers. Also where should i go shopping for parts to build these?
Appreciate any help for a first time builder.
Steve.
Probably not a bad idea. Look at Pass' Rushmore. I personally don't feel that the electronics shoild be in such an environment unless vibrations can be dealt with very well. However, it does eliminate all the BS about speaker cables.
Vic
For active speakers I most often build a compartment on the back that is sealed from the rest of the speakers. So one has to worry much less about vibrations.
The disadvantage is that the gross volume of the speaker will get much larger compared to putting the electronics into the "acoustical environment".
Charles
