"Active Power Filter" - old "ST" naming for Active Crossover Network with integrated Power Amplifier
on page 8/15 to 10/15 under
https://pdf.dzsc.com/88889/4193.pdf
(save in the attachment) there is to find the circuit description to such an active crossover network.
Colloquially, this term is obviously totally outdated, since I can't find any further publications on the web in this case.
The special feature of this active crossover network is the absence of additional gain stages consist mostly of operational amplifiers.
Who can me send the currently usual term for this topology (maybe to find in the application notes from TI, NS, LT or Analog devices) ?
Thank you very much
op amp stages in usual sallen key active crossover networks are mostly unity gain stable. Modify most power amp topologies in unity gain mode result in oscillating. The lower the gain determined by NFB network (at a given open-loop gain) the higher the degeneration into an oscillator.
But why should be unity gain in the power amp necessary for implementing an active crossover network ?
In the datasheet ( link ) of #1 this condition isn't present, also not here:
https://ampslab.com/blog/2022/04/08/biamppro-bench-test/
