Active notch filter
5th element said:
Yes that tells you how to calculate the value of the inductor.
But what about the frequency it all works at?
The Q of the notch? and
The size of the notch (db)?
I knew about that bit but not the rest.
You should probably step back for a minute and take a look at some of the tutorials on filter design.
TI has a good tutorial on their website.
Look I have used active filters in the past to great effect and am in the process of building another. I know how to use them. This project tho calls for a notch filter which I have never had to use before. So hence I dont know how to calculate one. All I need to know is the formulas. If TI has this which I will look into then great. I was just wondering wheather anyone knew the formula LW has used in that notch.
