Active Module Design
I make active modules such as line array, monitor, tower.
Behringer preamp chart has been added.
High output and low output level are adjusted with an equalizer according to its own speaker.
I will cancel the Behringer preamp equalizer piece.
And instead I will put 10 equal 2 equalizer bands on the other scheme.
How does it work? Where is the Behriger Opto connector X7 Pin going
