I'm designing an active analog crossover for a 4-way dipole, with mostly 4th order crossovers. I've got the basic schematics worked out and a working model laid out in LspCAD.
I understand the topologies, and the relationships between capacitors and resistors in a given circuit section. Once a particular cap size is selected the resistor value can be calculated (or vice versa).
How are the sizes of the capacitors or resistors (whichever are selected first) determined? Are there minimum/maximum size rules of thumb?
Thanks,
Paul
Thanks,
Paul
