Yes I like that one. If I wanted to say, add that to an amp I already built. Class c bias for am.. I used the ferrite transformers with the small ferrite bead to ground on the input and f bead to v+ on the output transformer, could I lift the one on the input and work in that circuitry? Or would I have to do those exact inductor values? I used the popular amp plans floating around online, plus a little ofmy own work.also would I need larger transistors w heat sinks or could I actually use 2222's?
Hey check out the final section on the cobra 148 gtl. It uses a series regulator to bias a 2sc1969. I plugged it into spice and looks ok.. I'm still novice though, im wondering how it would behave under load. It uses 1 Darlington with a diode from base to ground. I used zener in my sim. Worked better.
Thanks for the help man. I've been scratching my head on this for a while!
