Hi all.
I recently bought an AER compact 60 amp.
It is a very nice unit .but seems to lack low end.
I would Like to build a small sub for this amp.
My requirements would be around 100 watts
10 inch driver with a freq response between
60 and 240 hz..I know more of a low mid woofer..
I would ideally want this in a 1.5 cu ft enclosure.
This is like an acoustic guitar stack.
I need sources for crossovers plate amps and the speaker
Any help ideas??
Thx
Any help ideas??
Thx
Take the Amp back if it's not what you want. This might save you a lot of work and expense. you may not get the "right" sound with all the mods you mention.
Either that or use a tone peddle/parametric EQ or just the tone "stack" in your amp That involves changing a few resistors and caps and should give you more bottom end.
What size is the speaker in your amp? The speaker in a well designed amp should be able to deliver a wide frequency response, especially one designed for acoustic guitar.
Sorry I havn't answered your question, but I think you may be better with an amp your happy with, rather than trying to retrofit a seperate cab.
Andy.
I
Andy.
I
