OCC copper connector, aluminum case to provide best shielding of all EMI/RFI
suitable for cable less than 20mm diameter
Male Connectors + IEC Connectors
Prices :US$75/ 1 set
http://www.ab-system.hk
http://http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=260415090985
😉An externally hosted image should be here but it was not working when we last tested it.
The surface of the plug is adonised and the attached photo shows that the surface is not conducting current. But to be double safe, you can use heat shrink tube to cover the cable inside the plug.
A&B SYSTEMS
