Any advantages to using DC or AC for a heater voltage? Tube spec's state that either AC or DC can be used. Just wondering what the more experienced have to say about the subject.
not experienced
but page 6 of rc10 manual states that "Filament-cathode types of tubes are particularly well suited for operation from a steady source of filament supply voltage such as a battery"
and The heater-cathode construction is well adapted for use in radio tubes intended for operation from a-c power lines.
so this might be a start for recommended usage.
rgds
garbage
rgds
garbage
Unless you have problems with hum, just use AC. For a linestage or poweramp, I would probably use AC. For a phono preamp use DC.
If you use directly heated tubes with a heater voltage above 2.5V, using DC may be nescessary.
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
