AC Cap for DC use
The only caps I use now are GE or ASC PP in oils for the PSU.
Pete Millett made a post on the Tube DIY board at Audio Asylum a while back after he'd emailled ASC for their opinions on the safe DC working voltages from their AC cap ratings. The 1.414 John mentions above was about the minimum in most cases.
Hallo,
I have some of those AC use only paper in oil caps. They are are marked outside with the warning against PCB use. What does that mean? If we move the cap ouside the chasssis, then it's safe then?
My point is: if you can put or fix the cap on the PCB careful, then why it is dangerous?? Leakage? Very unlikely, right??
cchen
:scratch: :scratch: :scratch:
